9c1cap
- Western Maryland
So I picked up an '01 recently with a cracked 0331 for 400 bones. Towed it home and pulled the head to verify the problem and, indeed, it was cracked in the same place they all do. Picked up an 0630 from the 'yard and dropped it off at the machine shop. They took .006" off the deck, did a three-angle job and installed new, taller beehive springs and new guides and seals. I also had them deck the new header I bought and throw everything in the cook tank and bead blast the intake. I bored the TB out myself to approx. 60mm (just enough to remove most of the lip without going too far or getting into the butterfly seal. To test the TB I ran it on my '95 XJ for a week with no issues other than a slight whistle (had to plug the port for the MAP sensor of course).
So I get everything together with a new w/p, new IAT sensor, new CTS, cleaned injectors and rail, and new battery, and crank her over for the first time in my possession, NO START and Im getting air intermittenly popping thru the throttle body. Not a backfire, just puffs of air(no intake installed). Pulled a p0122 (IIRC) and a couple of trans codes so I ignored the trans codes and replaced the TPS with an Advanced unit. Return to the jeep and with new TPS installed I get a repeat of first start attempt only now Im getting just a p1391 code.
I have a few things I want to verify concerning the p1391 next time I can get to the jeep (stashed it at my brothers house) but the air popping thru the TB is a concern for me. I pulled the VC to make sure all the pushrods were installed correctly and seated on the lifters and I see no issues there. Just looking for some advice on what to check next. I dont have access to a computer while Im at the jeep and all I have is a Haynes for reference so I m trying to put together a checklist next time I can make it up there (have a 3mo old baby so time is limited). Any input or suggestions is greatly appreciated!!
Craig
Craig
