you seem to be leaking vacuum from inside the heaterbox then...or it's got a bad seal and the air is coming out there. tell me, does alot of air come out there when it's on low or off?
you probably should take out the heaterbox and put a new seal or w/e is there...but if you have bad vacuum there's a internal problem
this fix may help, but it's not your whole problem
