Alienspecimen
- Best Coast RI
I don't have any heat.
The blower motor does not work and also when I turn the dial the temperature that comes in does not change.
I think it happened while I was chasing another electrical issue. I took out each of the fuses from the electrical panel to check if there are any in need of replacement.
So I have two questions:
1. Can you verify that all the fuses are in the right place? I may have misplaced some.
2. The wire you see at the bottom...It was plugged in either to the 15A blue fuse or 20A yellow fuse on the left side (in the 8th and 9th slots respectively). Can you tell me what it is for and to which fuse it should be connected.
Thanks in advance
Boris
Here is the picture of the fuse box:
Thanks in advance
Boris
