Whelp..
Got them mounted with extended shackles, torqued on the ground with tires on and re-greased the bolts.. took very little but no surprise there.
I measured axle to 'frame' and compared with pre-swap OME 3.5" measurements on the same extended shackles, and gained exactly 1"; from 3.5" to 4.5", exactly what I had hoped. Shackle angle is not optimum but 15* to the rear so not 90* anyway, and as stated, I can further tune that with SF SRB if I feel the need.
Pinion angle with the same 4* shims went from 2.5* to 3*.
Took it for a spin around the hood on the same streets with cracked pavement where I notice my snap-crackle-pop on the old setup - that and washboards on the dirt. It's nearly completely gone.. like 99% so I'm very pleased so far.
I'll drive it a bit, get it out on the trail, check torque and re-measure to see where it's at then determine what to do up front. It is a little forward raked now but I expected and hoped for that. Plan is to go with Metalcloak progressive 4.5" coils (no spacers) and CAD.
Yup, I'm smilin'. Thanks folks!
