- Westminster, SoCal
2 core will flow better and 3 core have been known to have loose solder problems.LiquidOps said:Thanks for the info man...
I've been warned to not go to the 3 core though... too tight of a fit?
Yes no?
Steven
Yes no?
Steven
yeah it is but it's most commonly found in the 3 core radiators I have never heard of anyone with a 2 core one having that problem.cal said:Wouldnt lose solder problems be a manufacturer thing and not a 3 core thing?
Well... we're talking about 1800 radiator and I will have to say that all I know of are problem radiators coming out of there. In any case the fact that the 3 core has narrower passages it raises the likelyhood of clogging, but yes, you're right cheap radiators definately contribute to the problem.sintax said:3 cores more prone to having solder loose in them....this is how damn internet rumors start.
The amount of cores plays NO part in the chances of having shit in your pipes. Buying a el cheapo shitbox mexican GDI unit on the other hand really raises your odds of having problems. Find a nice Modine 2 core.
Come on Remi, i expected more from you then that.
cal said:Get all of your parts, and talk to me about a date. If needs be, i may be able to provide a location as well.
As far as a radiator goes, call "Gary's Radiator" in fullerton. He can build to oem spec or custom, i've had a few done there for some muscle cars or full size trucks i built before jeeps caught my eye.
Gary's Radiator Service, "A great place to take a Leak" (since 1954)
225 W. Truslow, Fullerton (off of Highland), 714-526-3367
Radiators, Air Conditioning. Accepts VISA/Master
-C
Sounds like you'll be up and running by Big BearLiquidOps said:Today is the day!!!
w00t... time to get this Jeep back up and runnin
wish me happy wrenching... and a huge huge thanks to Cal
Steven
Kejtar said:Sounds like you'll be up and running by Big Bear
LiquidOps said:ok... so here's the update... :gonnablow assgas:
Put a new head on, gaskets, plugs wires, hoses, radiator, t-stat, fricken everything you could think of...
Fired right up... w00t.... :sunshine:
Temp gauge climbed right up and pegged...
Ran a few tests...
Seems to be a bad water pump (the only thing we didn't replace)
So that's what we're doing Monday after work....
bah... a full day of :repair: and still more stuff....
:explosion
Steven
You guys put a new radiator in? Any chance it's restricting the flow?cal said:This is an open system, and is not quite as prone to air pocket problems.. but the system was pushing next to no water at all. After five or six minutes of running the lower hose was still full of cold water, and the upper was only slightly burning hot.
ok.. that's just scary!cal said:you can touch your tongue to the radiator cap or therm housing ..
well you figured wrong.. I'd herculine it and see how long it took it to set!cal said:well, i was thinking "i dont have a candy thermometer handy .. what would remi do?" ..
so the tongue it was.
