tomcat said:irony is a lifted jeep photographed in a mall parking lot....
xcm said:you need a new suspension for those size goals... and axles as well
and you definately need a slip yoke eliminator to eliminate those vibes
w0mps said:That's another thing, is the driveshaft situation. My front one I think maybe toast. I checked the U-joints (have to check them again) but they all seem fine, but its making a violent vibration with it in. My rear was out of a WJ I think, and rebuilt by a shaft shop. I'd like to get a new set of shafts, but it would probably be wise to wait until I am at the height I want to be at first, correct?
w0mps said:Okay so I finally made the decision to hold off on the longarms for the time being. I did decide to go with the Rubicon Express 4.5" Superflex kit, with the JKS disconnect and extreme duty tracbar and bracket upgrade. *Should I be okay with the fixed upper and lower control arms, or am I much better off going with the upgraded adjustable lowers and uppers?* I am planning on contacting Jason for the lift, I've heard good things.
So today, I started with the front, removed everything but the UCA's and steering. Finished painting all the wheel wells, and basically cleaned up. Here's a couple of pictures:
