Starscream
- Columbia, SC
I recently had a ton of electrical failures - not really sure why:
Bad alternator - replaced
Blown fuses under hood (dome lights, radio) - replaced
Blown CB fuse - replaced
Turn signals no longer work (but hazards do) - replaced combo flasher relay
I have read all the threads I've found on this subject. I have a combination turn/hazard flasher. I have replaced this and they still don't work. I know the bulbs and grounds for the lights are fine since they light just fine with my hazards on.
I'm reading some conflicting info. Some people say that the combo flasher is under the left knee-knocker panel, but the only one I've found was under the right side. Some people say there is a separate signal flasher to the left of the fuse panel inside. I have yet to find this.
Also, my repair manual (Haynes I believe) shows no info on the fuse panel layout, and my owners manual shows the wrong (shocking) fuse panel. I have checked the fuses with the numbers table in the owners manual and it says that fuse 8 is for the hazards/signals. Fuse 8 is fine. All the fuses are fine.
When I turn on the signals I get nothing - no interior indicators, no clicks, no external lights - nothing. When I turn on the hazards the interior indicators light, I get clicks, and the bulbs work fine all around.
The only thing I can think of is the signal/wiper combo stalk, but I'm still not sure why it wouldn't work when the hazards are in the same place.
Help. Please. This is ridiculous.
