831_xj
- Santa Cruz
Hmmm okay. Pics of your steering and tb?
Something is binding.
Okay man thanks for the knowledge! I'm gonna use slotted lower control arm mounts from a TJ now so I can have caster adjustability.
How are your flex joints in the control arms? I've been fighting the same issue just like your talking about. Every time I turned into my driveway too fast (coming off a steep hill and making the sharp left turn) I got a loud pop. Wheeling/articulation same thing. Fwiw I run no sway bars.
Thought it was my stock steering hitting the stock sway bar links (which it was hitting) so since I had rustys otk steering, track bar and brace to put on I cut the sway bar links off and installed my steering. Still had the pop.....
I had ordered RC flex joint rebuilds, so I pulled the arms, cleaned everything up, replaced one that was worn and greased them up and re-installed. Took care of about 90% of mine, I still have an occasional pop kind of sound but I'm blaming that on my totally wasted DS ball joints....
If you haven't done it already I'd just pull one arm at a time, take the joint apart, clean it grease it, tighten it up good and put it back.
Bolts to steering box tight? Do you have an inner brace or the chincy stock one? If the stock brace is broken in pieces it could cause a pop. So could loose bolts.
831_xj might be on to something there....
Or you just have a unibody with some bad spot welds that you may never locate lol. Honestly though its kinda hard to come up with much without actually seeing/feeling/hearing it... Good luck! Jeep looks like its setup well! A lot like mine actually...
X1000
Yes. A can bolt that ALSO doesn't hold your control arm in place via friction. The entire purpose of a cam bolt is to retain the bolts position in the mount. If friction did the job, why bother with can bolt ?
Check your frame side trackbar bracket ... I found it nearly inposssible to keep the bolts tight and it would move on compression/droop exactly as you are describing.
The clamp load of the inner faces of the joint is what holds it.
The physics of the system will not change. No matter how much BS you believe, friction is the only thing that holds those joints in.
Carrol Smith, the late race driver / team manager / mechanical engineer and prolific author on how to properly build / design / tune race cars, disagrees with you. In his book "Engineer to Win" and the Nuts, Bolts, Fasteners and Plumbing Handbook the man goes over this in some detail. What I took from it is that yes, friction helps and NO, it is not the only load bearing mechanism in the typical bolted joint. It may be the case that on a stock Jeep the hardware is sized enough that the frictional forces are adequate to keep things in place.
Put 37" tires on an XJ with a 10mm track bar connection and I contend that within a short time even a still-properly-torqued bolt will be wallowing out it's mounting lugs, friction bedamned.
I been wrong plenty of times in life but I'll go with the late Mr. Smith vs the stuff we all hear on the internet.
