I ran miller jeep trail last month and my xj did great. It was climbing everything easily up until i ran into problems. I was climbing a steep hill and i felt it lose power. I ended up giving it playing with the throttle to keep the engine from dying and the jeep was barely chugging along at 2k rpm. It stalled on me at the top of the hill but i was able to get it started immediately but the idle was real low and not responsive. I revved it a few times and it went back to normal so I kept driving it. About 20 minutes later I lost power again and it finally died. I was checking the connections but couldn't find anything obviously wrong. so we finally began towing it. A wrangler began pulling me in reverse back towards the start of the trail looking for a spot to turn me around. We finally got my jeep turned around and it started so i took off trying to make it back. Luckily it did start since i was able to drive my way through some of the harder sections of the trail and it finally died again in a clearing where you can head towards Yellow jacket trail. I let it sit there while i waited for my friends to catch up and was never able to get it started. My buddies brother ended up towing me out the rest of the way in his land cruiser.
I don't have spark. I checked the CPS using this video as a guide: https://www.youtube.com/watch?v=dPb6q40iAEY
and it checked out fine. I then used a multimeter and have power going into the coil but not coming out of it so I replaced it. It did start but idled real bad and shut off within 2 seconds and after that I was unable to get it started. I took the coil back and replaced it and had the exact same results. I then replaced the Distributor pickup coil and nothing happened. Any ideas on what else to check? I don't want to continue throwing parts at it hoping that it starts.
I had the engine replaced earlier this year. My xj is a 94 and I had a 96 4.0 installed.
