4.0 weighs 483lbs / 3.25" stroke / 85 or 90mm bore
4.7 is 82 lbs. heavier / better breathing heads / 3.33" stroke / 91mm bore
iron 4 bolt block - same platform Toyota went F-1 racing with.
Wiring in the ECM is the pita - major.
Both have very skinny con rods - no Turbo / Supercharging over 6lbs.
For the money - I would choose a '01 - '04 LINCOLN DOHC Navigator 5.4 engine - 330cu.in. - 310HP - wire harness & ECM mounted inside engine compartment.
3.55" bore
4.17" stroke
fully dressed shippping weight of 660 lbs.
my AMC 360 shipping weight is 740.
Parts / gaskets / seals are easily half the Toyota price.
Cams are chain driven as is the NEW Tundra 5.7
Stroke is whopping 4.17
Engine capable of spinning 8 K rpm.
Engine won a few Design Awards -
Buy in is less than half that of a Tundra 4.7 -
off
www.car-parts.com perhaps $1,200.00 for
a 2004 Navi 5.4 DOHC
NEW 2006 Navi 4wd Trans is based on the
ZF 6hp26 used in Maserati - BMW - Jag etc.
with rave reviews on engineering.
www.car-parts.com price ? a 2007 for $1k.
more:
http://www.naxja.org/forum/showthread.php?p=243505767#post243505767
anyone with a spare healthy 2wd AX-15 for my meager dream - Appreciated!
