- Williams AZ
1badxlxj said:The lexus/toyota 1UZ-FE engine spec's are 250hp @ 5600rpm & 260 ft/tq @ 4400 rpms.
The 4.0 jeep engine spec's are 177hp @ 4200rpm & 190ft/tq @ 4000rpm
Both of these engine spec's are for the 1990 year models.
I'd have to agree here. Even IF the 4.0 has a flatter curve, the V8's larger numbers would indicate that it has similar torque at lower rpms.PapaPump said:...and as far as the engine being peaky...pffft...when you are talkin' about an extra 60 lb-ft at peak, you aren't gonna miss anything at off-roading rpms. i'm sure the numbers at least match the jeep at low revs...
Heres a mock up with totally made up figures, but as you can see I gave the I6 a VERY flat curve and the V8 is "peaky".
RPM V8 I6
1000 140 140
2000 190 170
3000 225 180
4000 250 190
5000 250 170
6000 200 --
Even if I'm not accurate with the numbers, you can see that the V8 will always have more tq. than the I6. I see no way you would lose ground with the V8
BTW...Lets see some pics of the rig its going in.
I think the swap would be fun and "original" DO IT!
