jcroffroad
www.jcroffroad.com
- Kalamazoo, mi
Looking to upgrade your stock Jeep steering? Is your lifted Jeep having alignment problems? With our Jeep 1 ton steering upgrade, you eliminate the hard to adjust "Y" stock steering, it allows for a longer drag link to help with your steering angles, and most importantly gives you heavy duty steering that will take a beating and hold up to the off-road abuse.
The rods are a beefy 1.25" diameter DOM, with an almost .25" wall; threads are direct tapped into the tube. This means (unlike a threaded insert) the TRE has full thread engagement into the tube for the length of its threads. On this system the passenger side TRE dust boot is replaced with a polyurethane spacer, which pulls the body of the TRE against this knuckle. This eliminates the tie rod roll that an inverted T setup sometimes has.
available in Under the Knuckle ----> HERE
and Over the Knuckle ----> HERE
all the parts are available individually as well. check our website for more information ----> HERE
