I just Talked with Andy and he said he has Flex-Joints and will be Able to get more as needed. He also gave me his New Website Address.
http://www.ironman4x4fab.com/
þ Precision machined from 1" solid steel.
þ 5.75 inches of thread for up to 4 inches of adjustment.
þ Usable from stock height up to 8+ inches of lift.
þ Utilizes polyurethane bushings with our exclusive tapered bushing sleeves for 20% more flex than stand poly and rubber setups.
$114.50+ $16.00 Shipping
þ These arms are very strong! They are machined from one piece of 1.25" solid!
þ All welds are precision pulse mig welded. Bushings are polyurethane with grease veins and grease fittings.
þ Adjustable from 16"-20" eye-to-eye and weigh 16 lbs per pair.
þ 5 inches of 1.25 x 12 TPI provides 4" of adjustment for up to an 8" lift or more!
þ You can scoot your front axle forward with a smaller lift to run bigger tires.
$139.50+ $20.00 Shipping
UPPER:
LOWER:
þ Precision machined from one piece of 1.25" solid.
þ Bushings are polyurethane with grease veins and grease fittings.
þ Thread is 1.25 x 12 TPI.
þ These are overbuilt and comparable to the strength of most long arm kits.
þ Compare to any other control arm manufacturer.
þ Adjustable from 16"-20" eye-to-eye.
þ These weigh 16-lbs per pair.
þ 5" of thread means 4" of adjustment for up to an 8" lift or more.
þ You can also scoot your front axle forward with a smaller lift to run bigger tires.
$249.50+ $20.00 Shipping
$179.50+ $20.00 Shipping
Hopes this helps
