whitneyj
- Mayville, WI
how'd you cut the plate?
You guys obviously have never welded on a unibody. precautions must be made to make sure that the welding does not mess up the PCM and ECU. The only way to properly do this, you must uninstall the motor.
I hope to god you are kidding...
It was actually a bit of a joke. I was doing a motor swap, and ended up doing this at the same time.
LI might as well give this a shot while the welder is out. Since I don't have any steel lying around, would you recommend going thicker than 1/8" ? Or better yet, any reason not to?
cost to benefit ratio of 1/8" or bigger. btw, it'd be cheaper to buy sheet metal than 1/8" exactly... and 11g is .1196" thick. no... i haven't looked into this at all.
I have not managed to rip the frame from the frame yet, so thats always a good sign.:gee:how did this turn out? (bumper and all) ...just curious and going to be making some of my own TMR front unibody stiffeners
Anything thicker then 1/8'' is not only heavy and overkill, its also going to be a pita to weld onto the stock "framerails."Looks great. I just picked up a set of RuffStuff stiffeners http://www.ruffstuffspecialties.com/catalog/chassis-channel-reinforcement-p-291.html
Also, would removing the grounds be sufficient to reduce any risk of frying anything in your opinion?
Game. Set. Match.
Work looks excellent. I have a access to a portable sandblaster. Should help a lot with removal of the undercoating and all that crap.
I wouldnt put anything less than 1/4".
I remove the battery from the vehicle before welding, and un-plug the ECM just be safe.
Starboard M just fancies himself a desert racer, and used 1/8" - but he forgot the dimple dyes to make it strong enough! unless your an engineer, I wouldnt want to use less than 1/4" - because it might not be strong enough!
1/8" is more than fine, and I've never disconected the battery...
uhm, strong enough for what?
Are you being sarcastic?... 5/16" plate to the bottom? what in the hell are you doing with your rig that you need that kind of steel *anywhere* on an XJ?
1/4" is for upper control arms. LCAs and framerails need 5/16" minimum. That last 1/16" is vital.
Plus, it's down low, so it lowers both your CG and your ride height.
Glad you put the disclaimer about engineers, because they KNOW better than to try and use anything less than 1/4".
