ZacSquatch
- Fairbanks, AK
Of course... what kind of jeeper do you think i am....
ZacSquatch said:If your going to end up spend that much money on Hiems, why not run Johnny Joints or RE flex joints... around 50 bucks, rebuildable and scweeet.
WheelinJR said:I wouldn't do heims...rubber on at least one end for sure.
I run rubber all the way around myself and with my shocks disconnected (they're limiting me now) I can drop coils and overstretch brake lines.
ZacSquatch said:Of course... what kind of jeeper do you think i am....
No and yes,RE sell theirs with a female thread,so just weld the bolt in the arm!Or build up a shell like I did.lowrange2 said:Lol good point. I'll at least have supeflexs on the frame end of the LCAs. and mostlikly stock rubbers at the axle end. Don't they sell a supeflex joint with bolt already on it to thread into the arm for adjustment?
RCP Phx said:I look at it from the side of safety on the street.Radius arms "act" like torque arms,so I would rather share the load between instead of putting it all on one.Like I said you can make a "pin-able" "scissor" arm for the trail and have the best of both worlds!
RCP Phx said:No and yes,RE sell theirs with a female thread,so just weld the bolt in the arm!Or build up a shell like I did.
Goatman said:No more rubber for me. I hate the slop and I don't like having to replace them. Big heim joints are great because they stay tight and they never wear out.
WheelinJR said:You must be really hard on your Jeep. There are a few people running the arms I run, some for 3-5 years and have never needed to replace a rubber bushing.
I saw Goatman at JV & he does wheel the hell outa his JX..
With the wall thickness your using on the LCA mounts you never had a problem of streaching the wall where the stock bushing is? I couldn't get more than 2 trips on them before I had to remove the arm & beat tube round again so the bushing wouldn't want to walkout of the arm. That is one of the reasons I went to Johny Joints on my LCA's & their only $8 bux to rebuild.
If I didn't DD it I would do Like Goatman did & go all Heims & never have to worry about it again.
hellbilly04 said:With the wall thickness your using on the LCA mounts you never had a problem of streaching the wall where the stock bushing is? I couldn't get more than 2 trips on them before I had to remove the arm & beat tube round again so the bushing wouldn't want to walkout of the arm. That is one of the reasons I went to Johny Joints on my LCA's & their only $8 bux to rebuild.
No,thats a RE Super-flex joint.1-1/4"x12 threadlowrange2 said:Whats the thread in that RE piece? How much is it? - $58 You got that shell from JKS didn't ya? - yes $15 each Edit: Answered my own questions...
If you include the UCA there are 3 rubber joint per arm!lowrange2 said:The only thing I wonder is will having rubber bushings on one end of the LCAs and Superflex on the other end give me a harsh ride on the road? Will one rubber bushing be enough to absorb the road shock?
You need to have the flex joint at the crossmember,the ones on the axle will never see any movement(other than the compression from binding),all the movement(flex) is at the crossmember!lowrange2 said:Then thats what I'm gunna do! Rubber at one end or the other... I guess I'll do rubber at the frame end, superflex at the axle end, a hiem and the RK upper for the upper length. Decision made! Ordering tomorrow!
RCP Phx said:If you include the UCA there are 3 rubber joint per arm!
Read this again,everything is different when your only running one upper!Goatman said:The problem with running only one upper arm is that you can't use the stock axle side rubber UCA bushing, it's just not up to the challenge, and the axle wrap will be uncomfortable. I didn't like the axle wrap from using both stock rubber UCA bushings. With one upper arm, the joiunts need to be hard, like johnny joints or rod ends, and the axle mount needs to be reinforced to be very strong.
