HaZakated said:
Look...I'm done with this. Some of you people are acting like you are sure this cable clamp will fail, but you do not know for sure. Just like I do not know that it won't fail.
Honestly....I don't care if it fails. The probablilty of it hurting anyone in the event that it fails is about as probable as being killed by a Sting Ray.
If you feel the need to continue bashing me because of a possible flaw in a design I don't even like (if you read the entire thread), then waste all the time you want.
I will not post again to this thread.
For those of you who would like any information on any designs, sorry.
I don't get it. The CAD drawing showed a perfectly acceptable bolt on D-Ring arrangment, then you switched to this cable clamp thing. What happened? :dunno:
I personally would not trust the cable clamp. Most are not even grade 5 hardware, and they are use in a completely different application where strength is not a factor. The application you are using them in can experience very high side loads and extreme forces that may pull the u-bolt out of the nuts or fail completely. The price of failure of this part can be someones life, and for what, saving $10 each?
I see you posted you are starting a company, but you're low on bucks.
I would think
that would be even more reason to use accepted practices when building your product. After all, if you use a u-bolt cable clamp when people told you not to, you could be held criminaly negligent for any damages resulting from the use of your product.
On the Pin Clevis. These are generally used in Farm applications, but almost never used on the trail. Infact, many Clubs and Associations prohibit their use.
The reason is this: If they are not used properly, the clevis could be pulled so that the only thing which is holding the whole mess together is a hair pin in shear.
I have not seen an instance of a failure, and sometimes, I will use a pin clevis
if it is the only thing available.
Folks are just trying to help, I'd listen
