AussieDave
- melbourne australia
just be carefull not to overload your towbar,
i used to design towbars for Chrysler here in australia and they are only rated to take a certain amount of weight down on the ball.
I just know my 33's + bead locked rims weigh =100 lbs
2 x full jerry cans = 100lbs
1 x heigh lift = 40lbs
this totals 240lbs
Add the whip factor when you are going over bumps and you've already overloaded your towbar ( not in the pull direction which they are designed for). If this carrier stays long on your jeep with jerry cans and high lift jack you'll soo find some big cracks in your towbar.
Also i'd incorperate some sort of spring to help you lift the tyre back up to its ride position. Lifting a 100lb tyre everytime you want to get in the back of the car will get annoying real fast.
in my opinion swing out carriers are the only real way to go
this totals 240lbs
