seanof30306@yahoo. said:
96 XJ Up Country
While mine is a '96, it was one of the last ones built, and I'm pretty sure it has a '97 engine/pcm; the TPS, IAC, etc. I've put on it all ended up being '97 parts, not '96.
I have something very similar to what is described above that only happens every once in a great while, and only on cold starts. It has a hesitation a few seconds after I start off, it pops back through the throttle body once or twice, then clears up. One time this summer, on a 150 degree day with the AC running, it did it much worse than normal, after it had been running for awhile, and persisted for awhile instead of clearing up right away. I eventually booted the throttle a few times, and it cleared up.
It had another problem that may, or may not have been related. I was experimenting with hypermiling, and was coasting with the engine off, shutting it off at stoplights, drive throughs, etc. Shortly after I started doing that, though, the converter began unlocking and relocking while cruising, so I quit coasting with the engine off, assuming that was "confusing" the VSS. The converter problem cleared up.
I kept shutting it off at lights and drive throughs, though. It began giving me trouble on restarts, only doing so if I would floor it, and running poorly for awhile after that.
I reset the pcm, no change. Dit it again, no change. Dit it a third time, and the problem cleared up.
It didn't change the occasional cold start hesitation/popping, though. It still does it.
