DanMan2k06
- Damascus, MD
Just hit a deer on new year's eve. Total blower especially after just putting in a new oem radiator and some e-code headlights. Only a couple days old....
magimerlin:
just wondering why you came off the alternator for your +12vdc power to the relays rather then straight off the battery?
As a side note I used the gojeep and the fitchva walkthrough as guides when I built mine (I made a few little changes here and there) and I am convinced my setup is a lot beefier and better made then any aftermarket kit for less price... I'd reconsider building a harness if I were you.
that link takes me to an $18 high voltage wiring kit. Where are you seeing 30?
I made my harness using the Go-jeep plans. The biggest hitch is that the headlight terminals on the new sockets I bought will not accept 10 ga wire at all. It's not good to splice to a smaller lead wire, but at least they are factory crimped. Mine keep working out.
Let me take another swing at this. Fitch has a good write up with where to buy the stuff to make the harness. I follow this when I made my, no problems and works great.
http://fitchva.com/jeep/?p=57
Great guy to work with, I need help on his switch box and he got back to me right away with great answers.atriot:
All this talk about extra wire......couldn't you just cut the un-needed wire out of the harness and simply solder back together???
I don't see the big deal.....seriously c'mon.
That's electrical heresy
more like stupid.
if you know how to solder, wtf are you doing buying a wire harness that wont fit?
Ahaha, funny stuff.
I'm getting the kit because as of right now, I dont have the time to make one or to find the H4 pigtails.
I'll make my own later, I just needed a prototype.
To each his own.
My thoughts almost to a T... It's also easier and quicker to just cut off part of the kit you don't need and make those adjustments. At least in my opinion it is... assuming the kit you buy is of high quality and you have the parts needed to make the 'adjustments' to the existing kit to make it fit better.
I'll keep following this post so please (anyone who bought the kit) post a follow-up when you get yours and install it.
