Centrevillemx
- MD's Eastern Shore
...and a stand-alone Fuel Management System, not a bad way to spend ten thousand dollars..."
-Vin Diesel--The Fast and the Furious
Dr. Dyno said:For all the bolt-on performance mods, ported head, performance cam, and even a stroker, the stock PCM can adapt itself pretty well to these changes.
If you want more fuel you can get that either with larger injectors, an adjustable fuel pressure regulator (increase fuel pressure), or a MAP adjuster (increase injector duty cycle).
If you want more timing, you have to get a chip. The 4.0 doesn't need a lot of timing to produce full power (maximum advance 34 degrees) so it's doubtful that adding timing will help.
If you add forced induction you certainly need a custom engine management system. It can either be stand alone (managing all engine functions) or a piggyback system (manages only fuel and timing). The latter would be a more practical choice. One of the best on the market is the Perfect Power SMT-6 but it isn't cheap:
http://www.perfectpower.com/products/smt6.asp
Unfortunately it doesn't specify whether you'd need a 3-bar MAP sensor to monitor boost pressure (rather than vacuum).
