You can tell about what the ratio is by putting a mark on the ring gear and rotate it one full turn. Count how many times the pinion turns. If it makes just under 5 revolutions you have 4:88. If it turns just over 4 times its 4:10. 3 1/2 turns would be 3:55. and so on. Maybe someone else can give you the info you need by seeing the numbers. Hope this helps you out.
