Snwboarder673
- Nj
i pulled my tcase out today due to a crack in the rear half from the ujoint at rear diff failing...driveshaft is shot. when i originally pulled the tcase off to put on the sye no fluid came out from between the tcase and transmission. i dont know if that block that is between the tcase and transmission has a seal on it or not (the block that the crossmember bolts to) Should i pull the trans out and open it up? the fluid wasnt red and i replaced it and fliter last year with mobil 1......2000 xj with192000 miles on it
