Vanimal
- escondido, ca
Thanks man. it's not plated, i have about a foot and a half long piece of 3x3" .188 wall square tubing inside the rails, rosette welded to the frame stiffners on the other side of the rail.Thank Dan, I figure by the time this is finished I will finally know how to weld.
Your cross member is bad ass. Did you plate the inner unibody rails as well?
I was thinking about running two crush sleeves and long bolts through the unibody rail to sand which the inner and outer angle metal together. I think this would solve the twisting problem.
