Shogun
- Arizona Territory
For a really slick setup, go to the junk yard and pull a stock panel switch from another XJ, the fog light switch is the SPST one you need, and it has a little "on" light in it. Install this in a blank if you have one. Then pull power from the fuse block BATT position which is always hot (hot battery bus). Run the switched wire up to the alt fan relay and tap the #2/orange line. Then of course ground the third pin.
What you have now is auto (temp switch, a/c) and manual on. Now the neat item is that whichever method turns on the alt fan relay will illuminate the little indicator lamp in the switch because you tapped in between the fan diode and the relay and you Did Not install another diode to the switch. And it looks like a factory install.
