Muad'Dib said:
I tried this, but now im starting to think i did it wrong.
Im now thinking i can lift the front of the head really high and guide it into the engine bay with the back part of the head just low enough to get it lined up with the threaded rod. I thought in the begining that it would be too high to clear the firewall.. or maybe im just not thinking correctly anymore!?!?!
I trusted your advise 5-90, it wasnt that i didnt listen to you. I think im just doing something incorrectly or thinking too hard!
PS, i have seen alot of threads about head bolts.. people asking what size they are. On my 90, they are 5/8in 6pt. The threads i have read say a 13mm 12pt. So i hope that is usefull to someone.
Well to add to the mystery here, I just finsihed installing the new head bolts on my 89 that I bought from headbolts.com and guess what, the passenger side bolts were 16 mm, 6 point, (5/8" socket also fits ) and the drivers side were 18 mm, 6 point, deep socket! The old ones on the drivers side were 16 mm, the new ones were 18 mm!
The shape of the built in nut was also different on the new drivers side bolts. The old bolts had a built in flare like washer and smaller nut on top, while the new ones just had a larger nut with no washer like flare at the bottom.
Just finished torqing them all down. The rear drivers side bolt was real fun to get the torque wrench on, used a BFH on the torque wrench head to get it under the flange on the firewall and over the bolt, then used the BFH again to get it off, LOL. Oh, and duck tape helped get the head on with the rear bolt already in the head (taped in place) so I did not need to use the BFH on the fire wall flange that was in the way of installing and removing that bolt, bolt number 14.
I noticed that the Haynes manual called for using Perfect seal sealing compound on both sides of the head gasket, even coat both sides. Anybody ever heard of that stuff? I used Indian Head gasket shellac on mine, on the Felpro head gasket.
So why is that bolt #11 only gets 100 ft-pounds of torque while all the others get 110? I see that #11 is wet in the coolant area and needs to be protected with a coating, but I don't see why they spec less torque for it? If anything I would think it might need more torque. Just seems real odd! ????
Also, I noticed that the front most lower stud on the exhaust manifold also sits exposed to engine coolant on the back side of the stud. I sealed mine in the rear with Copper RTV before using 272 loctite on the threads to get a double seal, and make sure it is leak proof there and locked in place!
I also had fun trying to find and replace one exhaust stud that pretended to be 3/8"-27, but turned out to be 11mm (IIRC) after I tried to clean the threads with a 3/8" thread die. Turned out be some super fine metric thread, maybe 11mm -27 threads? Never figured it out exactly what it was as it was not in my thread gauge sets.
I found a good use for three of the old passenger side head bolts. I cut of the head / nut on three of them, cut a slot in the top and used them for guides as suggested here. Only used, and only needed 3 of them. I staggared them from the middle towards the front to make it easier to get the head installed in the rear. I reinstalled the E & I manifolds on the head before reinstalling the head, and the head went back on easier than it came off. I did have two strong guys helping me put it back on.
Oh, and 5-90 and 8mud,
I ended up using a 0.014 copper shim stock on the center two ports of the E-manifold on top of the Felpro e-manifold gasket and did some light filing on the outer ports of the E manifold to get it back to a reasonably flat fit on the head. Used the copper RTV 5-90 recomends too, and I think I got I reasonably good seal on it.
