aplatz
- Frederick, MD.
Just had a Banks Header, Catco hi-flow cat and dyno max cat-back exhaust installed and when cruising (not accelerating or coasting) I get a wierd bucking thing going on, It never happened before the install. If I step on the gas or let off it goes away. It happened at 50-60 mph, but seems it happens when your foot is on the gas just cruising.
I didn't do the install so I don't know what was removed in the process. Is something loose? The directions said to undo the motor mount (it is attached and seems ok. Should I detach the battery cables to reset the computer? Is this just a CSP, MAP sensor or TC vibe?
