cruiser54
- Prescott, Az
MMO is very thin.
MMO is very thin.
I've had two 4.0s with over 200k on each of them (I put at least 50k miles on each one).
Never once used any ZDDP additives, never bought premium oil. I just bought whatever was on sale at Autozone (Castrol, Mobil, etc.). Never synthetic.
I never once had a problem with them. All ran great, all were beat on hard (rev limiters every day), and never had any obnoxious noises other than piston slap since they were a '91 and '92.
We've also had an '87 Ramcharger with a 440 in it that has 60k miles on the engine. Never used a ZDDP additive except during initial break-in. Same thing, Autozone special oils. Never any unusual noises or smoking or anything.
I think the zinc thing is overhyped. Maybe not for racing applications or the like, but for everyday use I don't think it's necessary.
I recommend you read this article. It is one of the best I have found on the ZDDP/detergent/flat-tappet issue: http://www.kiwi-indian.com/pdf/EPQ409_36-39.pdf
So Lake Speed writes an article that is basically just a promotion of his team owner's own products and that is somehow an authoritative review of the subject?
Not hardly. Did you bother to read the entire article and, like a normal person with average skepticism do some follow up research?
It doesn't appear so.
While the last few paragraphs are a boost for a specific product the rest of the article lay out FACTS you can find with minimal effort. Further, those FACTS are laid out in a logical and concise format.
A mind--a terrible thing to waste. :twak:
While you have never put any ZDDP additives in yourself, it was used in your engine for the initial break-in period from the factory. The Mopar cam/lifter break-in additive is used for the first 1000 miles of a new flat-tappet engine, and it can be left in until the first oil change. Depending on the year of your XJ/4.0 engine, it likely was living on ZDDP for most of its miles.
No, the 4.0 isn't a high-performance flat-tappet engine, or a tweak British/Italian classic engine. Those engines are more prone to problems with low ZDDP oils throughout their service lives than the 4.0 engine is.
I run Shell Rotella T 10w30 in my 90's 4.0 engine for a number of reasons--first and foremost it keeps the guts of the engine cleaner than any non-diesel engine oils would; the second reason is it still contains a reasonable amount of ZDDP; the third reason is how it stands up to heavy load situations--as in off road use.
Actually Joe...
After having read a study about running a flat tappet engine using aircraft oil, which contains zero zddp, and having zero problems with the camshaft or lifters, I am very skeptical of the information that was presented in that article. Information, I may add, that was presented with zero actual proof.
Last time I checked aircraft engines did not use gasoline, but kerosene like fuel that is more like a diesel fuel than gasoline. Gasoline is more like a solvent, diluting oil, diesel is more like a lubricant than a solvent. Might have something to do with it. The ZDDP issue seems to be most hyper critical during break in period.
Actually Joe...
I'm not talking turbines...I'm talking piston driven.
My engines are worth a hell of a lot more than my cat is. Cats are cheap, engines are not. Lot less work to replace a cat too. I'll stick with my ZDDP thanks.ZDDP is not needed in anything but motors that run solid flat tappet lifters, not roller but old school solid. Its not recommended in modern day vehicles as it does destroy the catalytic converter so those of you in emission states could make an expensive mistake.
So to clarify for a stock xj ZDDP is not recommend and should only be used with solid lifters with no concern for catalytic converters
