so i got my durango box in a while ago. it works ok.
turning force seems ok, or even improved.
i may be feeling a hint of slowness, but i'm trying to determine if it's alignment or if it's slowness. it seems like it's a bit slow to return to center, it almost holds it's position wherever it's pointed. can the box cause this if the volume or pressure is low?
alignment checked and seemed to be pretty good, within spec.
it is because of higher volume the box requires. Naturally it will be slower than the almost 1/2" smaller piston in the stock XJ box.
