I just installed the Durango box in my rig and after it was in it would run out of power if the wheel is moved anything but very slowly. I gave this some thought and determined that the box was not getting enough flow to function properly. The fix was to remove the pressure line from the pump, remove the adapter it fits into and drill out the orifice a couple drill sizes bigger. I also removed the plunger that fits under that and took it apart. Inside of it there's a pressure bypass valve that allows fluid to bypass back into the pump intake when the flow is not needed. There are shims under the nut on the bottom of the plunger that control what pressure the bypass occurs at. I removed those, thereby putting more tension on the spring which makes it bypass at a higher pressure so more pressure goes to the gearbox. I put it all back together and installed a PSC 4.5" pulley and when I started it I could turn the whell as fast as I could at idle with no resistance. I haven't tried wheeling with it like this but I will soon. I expect it to be very powerful just like a whole PSC setup. I will do a writeup with pix as soon as I can get the spare I have modified and snap some pix.
