lazyxj
NAXJA Member #1310
- Los Angeles
I carry a portable jumper battery, in the XJ, to take care of dead batteries. It’s a less expensive way of providing the security of a second battery.
It works best for me since there is no room left under the hood for a second battery.
http://tinyurl.com/27ny2l8
I have used it more on other people’s cars than my own; it’s great for making new friends.
If you buy one, get the heaviest one you can find for maximum power output.
The lead-acid battery will hold a charge for a long time. I top it off once every month or so with a couple hours of charging with either the 120-VAC or 12-VDC charger.
My XJ has the biggest AGM battery that will fit the stock battery tray and it takes care of everything, including the winch, without problems.
Upgrading of all the heavy battery and charging wires/cables is a good idea for getting the best out of your electrical system. Make sure to upgrade the fuses and fusible links at the same time. Periodically checking the cables and connections for voltage drop should be part of your periodic maintenance. All connections get coated with dielectric grease to prevent corrosion.
In our motor home I have installed a marine 2-battery switch, the same that would be used in a XJ dual battery setup. A wired it using welding cable, including a new cable running from the switch to the starter.
http://tinyurl.com/27gpegg
The batteries are isolated with a dual-diode isolator.
http://tinyurl.com/26y5z6q
When the battery switch is in the 'both' position, the isolator is jumped, allowing power from either battery to flow to the other.
You can also use a voltage sensitive battery relay.
http://tinyurl.com/25stdxj
Being able to jump a dead starting battery with the twist of a switch is nice.
