- Wasatch Range
bluehummer.com
Heavy-duty front driveshaft disconnect. Simply slide the locking ring back to switch to 2WD. Slide it forward again and your ****** operates exactly as it did before.
Benefits:
Better fuel economy (up to 20%? improvement)
Reduced wear on drive train
Reduced vibrations on lifted rigs
Features: Heat-treated coupling and locking ring
Precision cut gear teeth and locking ring
Lifetime sealed bearings
Plated to resist rust and corrosion
High-speed balanced
Easy lock/unlock
Keyed to preserve drive shaft phasing
1-year parts warranty
Only problem, designed to fit Hummer H1.........but, why not an XJ?
Benefits:
High-speed balanced
Easy lock/unlock
