90Blue_XJ
- In yer postz fixin yer spellinz.
If no tags are there you will have to pull the cover and count teeth on the ring and pinion, I think. Can't figure another way except to rotate the pinion and see the amount of turns required to turn the tire one revolution. Then byou will have to approximate the ratio from the possible choices DC had for that particular year. Good Luck!
