XJ_Jeeper01
- Avondale, AZ
Well my driver's window stopped working a couple months ago. I took the door panel off and started inspecting the wires for any nicks or cuts in them. At first I thought it might be the switch or even the motor had crapped out. The Jeep had been sitting for quite awhile back in North Carolina and it wouldn't surprise me if all that moisture and humidity killed it. I discovered when messing with the wires that plug into the back of the switch panel that if I held the white wire in a certain position the window would work just fine.
This wire:
I did take the switch panel completely apart and cleaned the contacts on all of the switches just to be sure. They were pretty dirty when I took it apart. I put it all back together and it worked fine for a couple days and then it just stopped working again. I figured from driving around the vibrations moved the wire just enough to keep it from working. I took the door panel apart and tried moving the wire again to see if the window would work. No luck. I really don't know anything about electrical and I tried tracing that wire farther back to see if I could find anywhere it might be shorting out and no luck. All the other switches work perfectly fine and I really think it's just that wire and not the switch, motor or regulator. Anyone know which wires goes to which switch? Thanks.
This wire:
