ABS light after fixing broken speaker wires?
Benthos
Northern CA
Just did my broken speaker wires and replaced the faulty window control switch in the door. Went fine.
But now I have the abs light lit.
There's a ton of wire connections under drivers kick panel and I'm wondering if one is for ABS and got loose.
Fuses are ok.
Anyone know which connections are for abs or have ideas what i may have done?
There is no logical connection between your repairs and the ABS.
Start your diagnostics with the basics, inspect the sensors at the axle ends, compare the air gap of all the sensors, inspect the condition of the wires and trace their locations, check for corrosion and bent or pushed back wire plug pins. Check the ABS codes with your OBD-II trouble code reader.
X2. Get the codes read. That should help minimize the running in circles.
