Big Red
- Roscoe, IL 61073
I have a leak in my arb compressor and it needs a new "O" ring. Can I patch it up with some glue, silicone, pipe sealer, etc? It is a pretty small leak now at the top of the airtank. Otherwise I have quotes of around $235 for a new ARB compressor. I have a big 2-1/2 gallon tank/compressor that I just bought at Lowe's. It has a 100 psi max which is in the range of the arb requirement. Do you think I could hook my air line to it or do I need a pressure regulator switch to avoid damaging the arb unit in the diff? I would prefer patching up my existing arb comp, but the other big portable compressor is an option I hope, I want to have dual lockers for the con trip this weekend, without paying $$$ for a new ARB compressor now. It looks like part of the black rubber "O" ring is poking through the seal at the seam on the top. What do you guys suggest? Jes, I know this is a tech question, but I'm also seeking a place to possibly buy another compressor from if need be under $235 or so. What are your suggestions???
Troy
Troy
