little red cheroke
- Nashville TN
2001 jeep cherokee XJ
4.0/AW4/231 w sye
3" skyjacker lift with 2"spacers in front and 2" shackles rear
HP D30 front/8.8 rear
adjustable uppers and lowers
32" TSLs trail
31" MTs street
my steering sucks!! im getting alot of play at the 'frame' end of my trackbar (rustys )
my first step is replacing the TRE on the trackbar with a poly bushing.
next thing i wanna do is an OTK flip using either the JCR 1-ton kit or WJ knuckle swap.
im only on 32s on the rocks so i bang my steering up pretty good which is probably part of my problem and one reason i want to get it up out of the way.
my question is do i have room to correctly do an OTK flip? mostly concerend about moving the trackbar. i was going to go with the JKS bracket to move the track bar. and after that ditch the rustys POS trackbar and build my own.
also if i do a WJ swap can i make all my rods? can they all be straigt (straight track bar/draklink/tie rod)
thanks for the help and im open to any suggestions or other options
4.0/AW4/231 w sye
32" TSLs trail
31" MTs street
