JeepFreak21
- Cameron Park, CA
is there no info on the JK 44 on this thread?
It didn't exist when this thread was created. What info are you looking for?
Billy
A good swap for an XJ, if you want to run 5x5 wheels.
And redo all the brackets.
For all your JK axle swap needs let me know. I have swapped them in, ran them hard and found out what breaks.
So far the rear locker has failed. It sucks because there is no other locker available what so ever for the Rubicon Dana 44. I have to buy a new factory Mopar locker and hope it does not fail again. The electric magnet went weak and does not engage the locker all the way anymore. So you end up with an open diff all the time. I gues it could be worse and been something that left me stuck on the trail.
That is assumed with all dana 44 swaps (except for that TJ rubicon pile..) so I didnt bother to mention it.
Is that magnet an easily serviceable item? Seems kinda lame to have to replace the entire differential and redo the gear pattern setup.
That's the first failure like that I have heard of; it maybe a fluke? I've seen a couple of front housings bend or break, though.
If I were going to start from scratch today, it would be on JK axles.
While we are on the JK44, anyone heard of Mopar releasing the JK44 w/ TJ mounts. I read a caption in a Magazine that made mention of it.
Hey squirrel I know how to get ahold of the part. your talking about the mushroom thingy right?
FOR ALL:
on a JK remove the carrier before you remove the mushroom headed switch. otherwise it is expensive to fix.
A buddy of mine did this to his gf's JK with less than 2000 miles on it. I think its had more time on jack stands than on wheels at this point. He had some issues to say the least during the lift and mods that went into it.
