- Maurertown,Va.
There is a tool that uses a turn- buckle to push the seals in from the inside.If a person has two seal pushers of the correct size and some all-thread and some ingenuity they could make their own.falcon556 said:I do. I can't get them to go in straight. I use a combination of all threaded rod, socket and washers but this setup doesn't allow good control and the seal doesn't go straight.
If I knew the tube diameter in the seal area with a good degree of precision,
I might be able to have a disc made that will control the seal better.
Any ideas by the experts will be appreciated.
BTW has anybody tried RTV to seal them better?
Wayne
