9T3XJ
- FoCo, Colorado
Anybody else?
1.) I think the Currie joint for the UCA still uses a 10mm bolt, I would not trust a 10mm bolt in a three link.
2.) The passenger side UCA will need a lot of bracing if you plan on using it, at that point I would just cut it off and go with a more traditional mount and use a heim. After all, you are building a custom suspension, if you can't build your own mount you probably shouldn't be tackling this kind of project.
3.) Mount the heims however you can fit them.
4.) On a Cherokee frame end separation will be pretty limited unless you wanna start cutting up the floor.
And lastly, 3/4" heims will be fine for the uppers. 7/8" heims for the lowers will be strong enough but will wear much quicker then a 1.25" heim.
Edit: Just clicked on the Currie link, looks like it uses a 1/2" bolt which is still marginal. I would still just remake the mount.
