- Hartsville, South Carolina
I run a '98 Dodge 2500 master cylinder on a '95 ZJ dual-diaphragm booster, with the proportioning valve from the same ZJ (4 wheel disc). Calipers are the large single-pistons on the front 60 and the normal GM 1/2-ton ones on the rear.
Bias is perfect and stopping power & pedal feel are excellent.
I have the dual piston fronts and the stock xj proportioning valve. Why is the rear locking up but the front not? I thought with the factory set up there would be more pressure to the front bc it was already disk. Is my solution an adjustable proportioning valve for the rear or a zj prop valve?
