Begster
- Cape Cod/Boston, Mass
-79' Ford Bronco high pinion (reverse rotation) housing with axle tubes from a Wagoneer (3/8" thick instead of 1/4")
If it was reverse rotation, your front wheels would turn backwards when you stepped on the gas. Its reverse spiral, or reverse cut gears, they DO NOT rotate in the reverse direction.
Why didn't you just skip the hassle of retubing the '79 Bronco axle, and gotten a '77 or earlier? It would have saved you a lot of time, and it would have given you 1/2" thick axle tubes.
