Jump This
Just another minion!
- Borrego Springs Ca.
You must have been the one that I did the left/right dance with... left... wait... right... wait... left...
That was me too!
if it broke, it broke at the splines. only the driver's side wheel spins under power now, and i heard a pretty heathy popHow do you not know if you broke a front shaft?
That was me too!
FIFY!Good times guys. Next time let's get an earlier start so we'll have time for the knuckleheads with steering issues!
there were no tight turns at calico, not like CC anyways. he probably just didnt even notice.But he had no problems at Calico
Time to start planning for a June run!
the box has nothing to do with the throw of the pitman arm. the wj knuckles are longer in relation to the drag link mount to the center of the knuckle's rotation on the ball joints, so you need a longer pitman arm to get the throw you need, as far as i understand from what little i read on it. the WJ pitman arm is supposed to be longer than the xj arm.
As for the stops in the durango box, it seemed like he got the full 3.4 or 3.5 rotations, whatever it is. he double checked that.
he was talking about doing big bear in June. but it's a secret.Ummmmm June? What? Yesterday wasn't hot enough for ya John?. I was thinking like October.:dunno:
so i pulled the diff cover off, passenger wheel spins freely without so much as making a sound or disturbing the locker or carrier. it appears the shaft is broken. if that is the case, a big thumbs up to the riddler diff cover for probably keeping the ring gear from deflecting and leaving it in one piece instead of the shaft.
gotcha! thought it was a wj knuckle....I made sure the Durango box had the right number of turns (3.4) before I installed it. Same number of turns as the stock box so the pitman length shouldn't matter when comparing to the old setup.
Also, I don't have WJ knuckles...I do have the Tera Hi Steer knuckle and I guess it looks similar.
Steering was fine at Calico, although the steering wheel was knocked off center by about 40deg or so and I didn't readjust so that may have been the issue for not getting a full left turn. I haven't wheeled much since the Durango box/WJ pump swap, so jury is still out if it was worth it.
