Major components, such as suspension kits, must be readily available to the general public. Unless a modification is allowed or component listed as open herein, that part must remain original. Any component or assembly can be strengthened by adding material, but the original must remain intact.
1.1.1Body:
1.1.1.1 Stock unit construction body only. All body panels must retain original dimensions and material type (except front fenders, hood and fender flares). No internal body structure may be removed unless noted herein, except to allow passage of roll cage tube (where the hole must be welded closed using material of the same thickness removed. The stock rear upper shock mount crossmember may be removed or modified for installation of under-floor fuel cell. Stock seams may be rewelded, and material added for strength.
1.1.1.2Front fenders and hood may be replaced with units of any material. Fenders may have additional flare and wheel arch, but must have basic appearance of stock Jeep XJ model bodylines. Front bumper may be trimmed to match the new fender openings.
