Evan_in_CA
- Los Banos, CA
My son's 98 XJ is having this issue. No codes, runs great, zero obvious problems. We're going to get it smogged and two different shops get this error when they try to smog. Both places' computers say that it is ready to smog, but this happens when they actually try to start the tests.
Error on the last machine is "Minimum voltage not detected! Turn key fully off, re-seat connector, then re-start engine." Tech said the problem is "something electrical, that shit is expensive" so not a lot of help.
I'm assuming that one of the pins on the OBD port should have a signal but does not, but not sure how to go about figuring out which one. We checked pin 1 to pin 8 for voltage and get 14.1 so that seems fine. Advice?
