I am not familiar with the SSBC system, but usually you want the bleeder at the top of the caliper, above the line. That way, when you bleed, air an fluid will be forced in through the caliper, with the air going to the top and then out the bleeder. There is a bleeder on the soft line, but the problem I see with that is that when you bleed you will be forcing fluid/air through the lines, but not into the caliper and out. You could try to remove the caliper form the bracket, flip to the bottom bleeder is at the top and then bleed.
Apparently they have have different model numbers that end in "L" and "R" and I had those reversed. I flipped them. At this time I would like to extend my congratulations to the SSBC engineers and design team for using the most ancient parts to design a poorly engineered system that does noting it promises to do.
Using the calipers off of a '75 T-Bird
dunno
was quite possibly the most retarded decision ever. Instead of a straight piston you get a spiral and instead of modern pads that ride in shims you get some nice metal-on-metal action. If that isn't good enough, they used a system that requires that one take the whole damn caliper off to change the pads because those sliding bolts have a nut on the outboard side in a space to thin to get any normal wrench and it just turns and turns and turns from the other side.
Taking the whole caliper off would be easier if it were actually possible to get a socket on the lower bolt, but the space is too tight to even get the closed end of a wrench around the head of the bolt.
On top of that, when installed the correct way, which is apparently e-brake spring facing down, the D/S fixed cable is too short to make the run under the axle to snap into the bracket that I had to drill out to fit that terrible three barbed hook through.
The best part of my day was cross threading and then re tapping the threads on the two fixed bolts coming out of my new booster thanks to the pain in the ass and wholly unnecessary steel bracket holding the prop valve in place.
So...I have a new booster, new adjustable prop valve and I flipped the calipers. I ran out of brass crush washers for the caliper swap so I won't know anything until I replace those tomorrow and bleed it out. I also lubed up those rear calipers like a cheap date, so, they should slide at least half decent.
