Hey everyone,
Went to BB today to play in the snow. I purchsed a map and a trail book at the Discovery Center and they proved to be invaluable.
There was plenty of snow, ice, and mudd. After a couple of miles, we got into some soft snow. I had use a shovel a couple of times to dig out around the tires. We take 3N16 around to 3N14. 3N14 had lees snow, but more mudd. We continued down 3N14 to 3N08 (Holcomb Creek). I knew the hill at the crek crossing would be icy so we went to take a look. The creek was frozen at the crossing and the hill right all ice on the right side. I slowly drove onto the iced over creek to get a better look. All of a sudden the ice broke. I had crossed this area before and I knew the depth was only about 16 inches. So I went on and tried to clinb the hill anyways. No luck! My tires were spinning forward and I was sliding backwards. My right rear dropped into a hole. My rear tire stuffed up against the fendy and popped the flare and bumper cap loose. Shane also gave it a try, but no way. So we turned around, we only wanted to try hat hill. Even if we would have made it, I would not attempt that trail with only 2 non-locked Jeeps.
We went the opposite direction on 3n08 and took it back over to Holocmb Valley. The sun had been shinning all morning and the snow was melting so there was plenty of mud. We stopped at the junction of 3N16 and 3N10 (way to John Bull) because I heard a noise coming from my Jeep. My rear fender flare had come all of the way off and was being held on by 1 bolt. I removed it and the bumper cap. This was the only problem we encountered.
The snow was still over a foot deep. escpecially on the back side of the trails we the sun does not get to melt it away.
I did take a few pictures and will post them in the next day or so.
We may be running a similar route next weekend.
BTW,
Here is the run info again. There are several people expected so be there early!
Required Equipment:
Solid recovery points front and rear (tow hooks, shackles/d-rings, receivers), first aid kit, fire extinguisher, snatch strap (no chains, no strap with metal hooks), full size spare tire and all necessary hardware.
**You may want to have tire chains/cables, shovel, and extra pair of socks**
Meeting Place:
Big Bear Discovery Center (
http://www.bigbear.info/), 8:00 AM - departing at 8:30 sahrp.
Planned trails for Saturday:
Polique (2N09) to Holcomb Valley (3N16), Hanna Flat (3N14), & 3N08. All trails are open for discussion and depend on weather.
They are expecting an additional 5+ inches of snow between now and nex Saturday.
CB Channel:
Primary, 4; alternate, 14
Trail Leader, Saturday:
Robert Prater (rpratexj) - Inless someone else wants to lead.
Don't forget your cameras!
