RedHeep
NAXJA #1499
- Landenberg, PA
Depends on how it drives. Did you notice a difference?
Have you tried the chalk test?
You have to remember that we ask truck tires to perform well for us on a vehicle that doesn't necessarily weigh what a truck does. That's why you never inflate your tires to the numbers on the tire, always to the numbers in the door jam.
Unfortunately, when you go bigger (or to a stronger tire with a stiffer sidewall) your factory recommendations go right out the window. You have to find the happy medium.
I ran 30 when I was on 31's, but only because I wanted to squeek a little mileage out of the old girl. I probably should have been around 28.
I read about a way to gauge tire pressure a long time ago on another car board. The poster suggested inflating them cold (you always do it before you drive right?) and then going for a 20 minute trip somewhere. Check the pressure again and you should only see 4-5 psi rise because of the heat. More than that means too much air. Now that might only work on a small car tire, but you get the idea.
I have BFG AT's on my F250 and it's driven almost exclusively on the road, towing, etc. I've never had a single issue in weather and it rains about 100 times more here on the coast than where you are.
