Fletchs90xj
- Vancouver BC, Canada
Dingo509 said:I think some of us understand the physical part of soldering all this together but not the operational part. So i have a couple questions.
1. First how do i go about looking up the IC's? I have tried to search for just a 4511 and can't find it.
2. I assume Vcc is positive voltage? Is this 5V or 12V? regulated or not?
3. What wattage should the resisters be?
Thanks for all the help.
Dingo
Well the nice thing about CMOS logic IC is that they have a wide opperation range. [usually 3-18Vdc] So I used a SPDT switch to turn off power to the TCU and redirect it to my controller and filtered it with a 1000uF capacitor. The resistors are all 1/4W. You should be able to just google the IC numbers thats how I usually do it.
4511 - 7 Seg driver.
4516 - Up/Dn counter
4001 - Quad 2 input NOR
4081 - Quad 2 input AND
4069 - Hex Inverter ( I used this instead of the 7404, which is the part my schmatic prgm had in it, ya I'm lazy)
7414 - Hex Schmitt Trigger Inverters
4013 - Dual D Flip Flop
HTH
Fletch
90 XJ 4.0 AW4 w/Tiptronic 242
D30 Currie HP9 disc all round
4.10 ARB both ends
OBA, Xantrex 1750+
Dual Optima
K&N, Safari Snorkel
8" lift Rancho9000x w/in-cab
35"MTRs
M8000 multi mount
