Nice work on the controllers. I have a few questions about basic AW4 control. Do the shift solenoids run on full 12VDC? How many amps? Are you guys using relays and microswitches , or just microswitches for solenoid control?
I am running a '96 XJ- AW-4 body with a 3.0L Non turbo Mercedes diesel. I just started road testing a few days ago, and I am having shifter issues. I am on the fence about making a stand alone trans controller, because at present I have partial success operating in "D", and I would prefer if possible to have a option for fully automatic shifting.
At present, I have the old jeep Throttle body hooked up to its 3 sensors, and the throttle body is just hanging not hooked up to anything else. The jeep throttle cable is hooked up to the MB injector pump and that works well. I have not hooked up the cable that goes to the trans ( NSS?),. So the TPS is hooked up but not moving, the trans cable/NSS is doing nothing.
When the trans is not connected to the TCU, I get manual shifting I think position 1-2 = 1st gear, position 3=3rd, and D=4th with no lockup. When I hook up the trans to the TCU, I only get 1st gear in any position, when I flip the switch for the E-fan (manually jumpered on the bottom of the electric distribution box on the bottom of the E-fan relay, then the trans will shift in D, and I get 1,2,3,4. I have not gone fast enough to see if I get a TC lock up ( death wobble), and the shift points are not at the best speeds. All this is happening and I lost my speedo indication somewhere along the way.
I am hoping to get the trans cable/NSS hooked up but as it moves opposite the throttle, I will have to make a long bracket that will work opposite the throttle. The Throttle position sensor has more travel/rotation than the MB injector pump by quite a few degrees of rotation, so if I want that to work I will have to make some sort of bell crank travel extension for it, which is going to be a PIA, I can do it but it will be a pain.
So far my best success has been with the trans hooked up to the TCU, but I lost the speedo. A manual controller might be nice as the little benz needs to hold on to 2nd and 3rd longer than it currently is, OR that problem may fix itself if I get the TPS and the NSS working as intended. I still need to figure out the speedo.
Any thoughts on why I lost the speedo. all the sensors are hooked up except one O2 sensor in the exhaust.
Any help would be appreciated
