javelin401
- South Carolina
Wife talking sell now,assgas: so you know its serious. Intermittent issue, slippage in 1st gear in drive, hooks right up selecting 1,2 range. engine light on, throwing 3 solenoid codes (p0753 shift sole A, p0758 shift sole B, p0743 torque converter clutch sole circuit). When it shifts normal, engine light shuts off after a toggle (run/off/run) session and lights again when she starts slipping. All 3 soles ohm good when I had the pan down. Trans mechanic wont take my money, says its an electrical issue. This began shortly after a trans pull for a flex plate swap but all connections look good. Maybe a TCM or wiring issue, Next move: ohm solenoids from the TCM connector pinouts. I have the FSM to help.
I have researched past related threads but they are aged (transonline site 4sale) The throttle position sensor is properly adjusted, new neutral safety sw. Ive been cleaning grounds as ive been going thru this restore since July and its getting frustrating as f here. AW4 4WD
thanks for any help folks!
